Plywood Cases
Similar construction as Astroboard but used for heavier and more kit.
Custom Plywood Cases
Our 7 and 10mm birch ply cases are built to the highest quality available. We use a super strong and rigid construction method along with premium fixtures and fittings to give you confidence you need to ship your kit from A to B.
Fully custom, these can be made for what you may need to serve across many markets.
Uses of Plywood Cases
Plywood cases shine in the field and on the move. Musicians trust them for guitars, violins, and vintage vinyl; photographers and cinematographers pack lenses and cameras with confidence; toolmakers, machinists, and field technicians build entire mobile workstations inside them. Trade shows, museums, militaries, drone teams, and even traveling mixologists choose plywood for its unmatched strength-to-weight ratio, dent resistance, and the honest, timeless look of sealed  birch.
Example Plywood Case Designs
Severn Healthcare Illumigo Lamp
Stacked Rack Cases
SkyPanel s30
MIxing Desk Trunk
Lumenis Acupulse Duo
Aircraft wheels in plywood case
Tribe Blackwing Name on Case
Custom DIT Flight case
wooden_product1
Double_Monitor_Trunk
wooden_product3
wooden_product2
19U Heavy Duty shock mounted frame
Plywood shock mounted case 7mm
Sony-Bravia-42-inch-screen-large
Indy-Dolly-1
