Custom Flight Cases Designed and Manufactured in the UK
Aluminium, Astroboard, Plywood, Plastic and Padded Soft Bags
Custom Flight Cases For Professional Equipment
We design and manufacture custom flight cases for transporting high-value and sensitive equipment. Built to your exact specifications, our bespoke flight cases provide maximum protection, durability and ease of transport across demanding professional environments.
As a UK-based flight case manufacturer, we supply custom solutions for broadcast, medical, defence and industrial applications, with precision CNC-cut foam inserts for a perfect fit.
Detailed Design
Over the years we’ve come up with designs for some key components which are unique to Case Design – including our rigidised aluminium panels and aluminium extrusions which are produced to our own specification and our readily identified and securely stacked corners.
Best In Class Foam
The internals of our cases are constructed from our unique high quality foam. We use a variety of types foam to provide the necessary level of protection, including Plastazote and Etha Foam. The foam is shaped to your unique design using our high-speed CNC route.
In House Manufacture
Our policy is to offer high quality products to meet a broad range of market needs. We manufacture our own products and partner with market leading organisations. Wherever possible we use components that are readily available and can be sourced in the UK.
Impact Protective Custom Foam For Your Equipment
Our Bespoke Case Development Approach
The team at Case Design are always a pleasure to work with and conjure up exactly what we need with sometimes very tight turnarounds & the cases are always top notch
“Finepoint have been using Case Design for many years, have always been delighted with the quality and service. Quality cases to protect valuable assets. We have cases from 25 years ago, still in great condition after years of abuse.”
“We can always rely on Case Design to cut cases to our specific needs and requirements; and often can get us out of trouble with tight turn arounds. Every time we collect or drop off new kit, they are very helpful with advice and it is a very friendly environment too.”
“Case Design provide an exceptional service in all aspects – offer great advice and expertise, flexible when it comes to design adaptations and changes, and the build quality of the casing itself is outstanding. A great company to work with, highly recommended to all!”
